Leespread
6 years agoFreshman
Cost after 24 months
I'm approaching the end of my first 24 month contract - will my cost remain the same if I don't change my plan?
Thanks for your reply - I did find that I'm receiving a discount currently.
C0RR0SIVE
6 years agoAssociate Professor
Your service plan cost will remain the same, unless you change your service plan. Be aware if you change your plan to something else, your old one may not be available to you anymore. The only time costs will change is from plan changes, token purchases, or other services you might add or cancel.
