leslie50
8 years agoNew Poster
Data Usage
I can't find any info on my problem, so I am starting fresh here. I have had HughesNet for about 5 months. (I have a 50gb plan, I previously had DishNet for about 10 years with 15gb plan and 2 teena...
Maximus
8 years agoFreshman
Leslie I think you are on to something.... I did a comparison with Hughesnet and 2 other services I use watching the same 1 hour Netflicks show found Hughesnet data usage to be almost double.
HughesNet 984 Mbs
Service provider #2 435 Mbs
Service provider #3 350 Mbs
Ran the test several times all with HughesNet the winner.
I should also mention that after 2 months I have never come close to the 25/3 Mbps that are advertised.
I average 10Mbps on the down and under 2Mbps on the up.
I have tried no less than 50 Hughesnet speed tests as well as third party "testmy.net" allmuch lower than I signed on for.
Good luck I guess its Buyer beware.
