leslie50
8 years agoNew Poster
Data Usage
I can't find any info on my problem, so I am starting fresh here. I have had HughesNet for about 5 months. (I have a 50gb plan, I previously had DishNet for about 10 years with 15gb plan and 2 teena...
Chichi
8 years agoNew Member
The same thing is happening to us we us up our data in the fist 5 days of the month. I think this is a scam to make your bill higher or make you buy more data...
If you'd like to work on figuring out what's chewing through your data in five days, you should start a new topic, which you can do by clicking on the blue "Start a topic" button on the upper right from within the Tech Support section.
There's no scam. Something is using your data. You just have to figure out what and why.
