kathynaylor's avatar
kathynaylor
8 years ago
Tokens and upgrade error
Hi, Just looked at the new site and realized that my tokens are gone or I am looking for them in the wrong place.   Also wanted to look at Gen5 plans and am gettting an error message each time I c...
  • kathynaylor's avatar
    kathynaylor
    8 years ago
    Thanks for your quick response, GabeU.  The status meter showed 0 token bytes available, but when I selected purchase tokens, they showed on that screen. Thanks!  You solved that problem!
    About the upgrade:  I want to see my options in writing online before making any chang.  I was burned before and the thought of getting on the phone with HughesNet customer care people literally gives me a stomache ache.
    There is probably a better topic to post that issue under, so let's consider the taken issue SOLVED.  Good on you, GabeU!
    Kathy
