Sales Call Review
Thank you for providing me this information. I was able to locate the account. After running diagnostics, it appears the equipment is fully operational, however, we are unable to run a remote speed test due to frequent time outs. This could be due to the fact that both your site location and Gateway location are experiencing heavy cloud coverage at the moment. This can interfere with the signal and our remote tools as well. In the meantime, I would like to get your speeds documented before I begin reviewing the sales call. Also, once I launch the investigation, I will be listening for guarantees of speed or any other misinformation that may have been stated.
In regards to running the speed test on testmy.net, here are the instructions below:
Please do these tests while directly connected to the HughesNet modem with a LAN cable (wifi must be disabled*, NO third party Router or Wireless devices can be used for testing) -use the 25MB size download test file ONLY.
-post your results URL here, it may look something like http://testmy.net/quickstats/yourusername
For a more in-depth guide on running the tests, please visit: http://hninfo.us/speedtest *If you don't know how to disable the wifi in the HT2000W, read "How do I manage my built-in WiFi modem?" in this PDF: http://customer.kb.hughesnet.com/Documents/1041318-0001_a.pdf
Click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, 2.4Ghz Guest, 5Ghz, 5Ghz Guest).
-Damian
sunny day, no clouds, I suggest you have one of the technicians use BirDog, I cant run test now.
But the issues your having show you that there is a site problem..
Have a tech use BirDog.
First, as you'll note, Damian mentioned your gateway when referring to the weather. Bad weather at your gateway can affect your service just like weather at your own location. When the weather is clear, Damian (or any other rep here) will be able to remotely see if your dish is out of alignment and whether a tech visit will be needed.
Secondly, BirdDog was a customer, not a HughesNet employee. He's no longer a HughesNet customer and no longer posts on this Community.
- icyman616 years agoFreshman
he said and I quote "This could be due to the fact that both your site location and Gateway location are experiencing heavy cloud coverage at the moment. This can interfere with the signal and our remote tools as well. "
Both, my site was good, sunny clear skies, so that variable is out of the question.
I bet if you would tell me where the Gateway is, It had clear skies too. I would bet you money. And I would check it! Instead of just saying a possible cloud cover!
When I said have a technician use "BirDog" I am talking about a tool that runs around 750 to 1200 dollars.
http://www.birdog.tv/default.aspx?page=12
https://www.amazon.com/Birdog-USB-Plus-Satellite-Compatible/dp/B001IX00XU
Instead of everyone trying to Bully me, or take up for each other, or talk down to me, why not look at the real problem, which is most likely a misaligned dish. This is why I called originally, but instead of fixing the issue they gave us more tokens, then said too bad, look t the agreement, not try to really help. But taking up for all their other coworkers whether they are correct or not, right or wrong.
AND look into the fact the sales rep and the webpages state that I was going to get around 1 to 3 MBPS after my data was out. But now I am told no that not true!
Now within minutes one of you is going to come back to give some illogical explanation for whatever, in an attempt to say the problem is something else.
I believe if Hughes net sends a knowledgable technician who is not lazy and will climb to the dish, run diagnostics or maybe use a meter like BirDog they will surely find my dish is out of alignment.
I wasn't referring to your home location, but your gateway. I assumed my reply made that evident. And I have no idea where your gateway is.
And I'm sure that the rep and/or tech will use whatever equipment and software is applicable. They've been doing this for a little while, so they have what they need.
I'm not going to argue with you, nor bother to further try to help you, as you evidently already know better than everyone else. Good luck with that, and good luck to you.
