Upgrade charge is ridiculous!!
Actually, you'd have to wait at least 45 days after the cancellation of your current service to sign up as a new customer.
The free installation deals are to attract new customers. It costs money to not only pay the subcontractor to come to your home and perform the installation, but also for the parts that aren't included in the equipment lease, as you're only leasing the modem and radio, not the dish, the pole and all of the hardware required to install it. If the only thing required for the upgrade was swapping the modem, the upgrade would likely be free to existing customers as well.
HughesNet is no different in this than countless other companies that offer services that require professional equipment installation. New customers always get the best deals.
- Kristis67ss2 years agoFreshman
Yes I understand they have to pay the tech to come out to my house. But $300 to change the dish on my roof, which they will most likely use the same screws from the old one, and to unplug the old modem and plug in the new one, using the same lines already installed, is not $300 worth of hardware and work. Heck, the new install fee was only $150. So I'm sorry but no matter how much you feel you need to defend them you just can't convince me that this is even close to right! More should be done to keep their existing customers happy too!
- maratsade2 years agoDistinguished Professor IV
Would you like the Hughesnet corporate reps on this site to look at your situation and see if they can help? This site being for technical support and billing/account support and not for reviews or venting, you'd best serve your own interests if you asked the reps to help you. They are higher up the food chain in the corporate structure and may be able to do something for you.
While this is likely not guaranteed, what have you got to lose? If they say they can do nothing, you'll be in the same situation you are now. But they might have some kind of offer for you. Don't give up; ask for help. You're in the best place for that.
Yes, I would absolutely like to see if the corporate reps can help! Can you please tell me how I contact a corporate rep? When I call it's obviously not a corporate representative, they are the ones that tell me it's $300 and will offer nothing else. Believe me, I've asked. So any direction you can help me with would be greatly appreciated!
