System Control Center link incorrect...
The SCC link under "My Account" on the upper right is www.systemcontrolcenter.com, which doesn't work. It should be http://systemcontrolcenter.com.
If you are using a third party DNS, that will happen, it's why I don't always suggest using a third party DNS unless it's for troubleshooting purposes... If you must use a third party DNS, make sure the local DNS server on your router lets you input your own records that way you can get around that issue.
Strangely, www.systemcontrolcenter.com works just fine for me... :-\
Interesting. I basically get the same message with IE, Chrome or Firefox....
Well, geez, now the "correct" link I put in the post isn't even working. Now I'm stuck with 192.168.0.1.
- 3 months ago
