Sgelsinger
7 years agoNew Poster
True Review
Funny story that I'll keep brief...I am very rural like out in country... I call Hughesnet and ask 1 simple question.."Can i play on xbox live with this internet"...they say yes i can so i spend nearl...
MarkJFine
7 years agoProfessor
1. Speed has nothing to do with xbox live issues, it's the minimum 500ms latency that's inherent to *every* satellite internet system. Technically, you can play anything you want. I download games and get on xbox live just fine. It doesn't mean it will play well or that you'll be able to even come close to win in a head-to-head situation. Bottom line: you asked the wrong question.
2. Punctuation and spelling helps to get your point across better. 'Cause ya, I'm sure you're not 12 anymore.
