Gen5 HT2000W Power Usage
DavidSTX,
According to my APC Back-UPS Pro 1500va unit, the modem (HT2000w) is drawing about 40w at idle with clouds and a signal of ~110. Granted this is using the information the UPS provides and isn't very accurate, it should be a better estimate than initially stated. Probably wouldn't go up but 5-10w at most in stormy weather.
C0RR0SIVE
If I remember right the wattage they list is the absolute maximum possible wattage the system could use, and I think that's only if a weired short/failure occurs. I know the HT1100 is using between 17w and 29w on average for me, typical router is probably about 25-30w depending on CPU in it, so I would estimate a maximum power load around 60w for every day activities during bad weather events.
Really wish I had my HT2000W already so I could tell you the exact power draw under what conditions. :(
- DavidSTX9 years agoFreshman
Thanks, thats good info.
DavidSTX,
C0RR0SIVE- DavidSTX9 years agoFreshman
Thanks CORROSIVE, you rock... 40 watts is not bad at all, and clear skies are the norm here in the desert. My recevie strength is usally about a 170-180 on the hn9000, so it should do good here. Now just have to wait until payday to buy the equiment. Have fun with the HT2000W testing, I look forward to that review.
Dave
