25mps speed but Safari and Firefox load very slow
Good morning RJMFHWA,
Thanks - I only wish the install technician had placed the modem in my bedroo. where I originally wanted it, instead he placed in the living room which makes it difficult to run a landline into my bedroom.
RJMFHWA wrote:Thanks - I only wish the install technician had placed the modem in my bedroo. where I originally wanted it, instead he placed in the living room which makes it difficult to run a landline into my bedroom.
If your neighbors are running multiple WiFi routers, then it can be tricky or impossible to configure the WiFi around them. I found that even one other WiFi on 2.4Ghz with a strength above -65dB and your 2.4Ghz WiFi will back down to 1 channel even if configured to use 2 channels, and if they are on an overlapping channel things get very bad. I use a Netgear Powerline to allow connecting the computers using the network connection using the electric plugs as it is easy to setup.
