Cannot connect to wireless HP D110 printer with Gen5 wireless
Your printer may not support the wireless security cipher the HT2000w uses by default...
1: Visit http://systemcontrolcenter.com or http://192.168.0.1
2: Click Wifi-Setting on the left
3: Enter the password to access your wifi settings, by default it is admin4: On the 2.4Ghz tab change the WPA Mode to WPA/WPA2, your cipher suite should change to TKIP+AES
5: Try reconnecting the printer, using the password that is displayed in the password field on that section.
Thanks so much for this post!! We struggled for 2 days with this issue. We used this and Viola!!! We are printing!!!
