Generator Internet Connection Issue
We've just installed a backup generator that offers remote access to the manufacturer and vendor, and us as well. But it can't make an internet connection. I was told to use specific IP addresses and ports, but I can't figure out the settings for the modem. I called HughesNet, but no help there.
I agree with Gabe, looking at the internet connection related parts of the generator's manual, it doesn't specify that the generator itself is wifi enabled, but that it has an ethernet port. Hopefully there's another contact option for the manufacturer that could confirm whether this is an actual feature.
What I can do is confirm that the internet we provide is working and that your wifi is also operational, as I can see multiple devices connected to both your 2.4 GHz and 5 GHz wifi networks.
- LizModerator
Good morning MuttCat,
I see it's your first post here, so welcome to the community! As indicated by one of the previous reps that assisted you, we don't block ports so you have many to try. The only exception is port 25, which was formerly used for e-mail, but we (and pretty much all ISPs) block it to combat spam.
If you could provide more info about this generator you're trying to connect to, that could be more helpful. Maybe someone here in the community who has the same one will have more insight. Otherwise, the generator's manufacturer may have their own support resources that can assist you getting connected.
- MuttCatFreshman
It is a **bleep**ins standby home generator. **bleep**ins does not offer any internet support. All the installation instructions indicate a hardwire ethernet connection to the router, but the installer says wireless is OK...I have not been able to verify this. **bleep**ins does suggest disabling the router firewall..I did...no sucess, still not connecting.
- LizModerator
Oh dear, do you have the manufacturer's website or a link to the generator manual?
Edit: perhaps it's this? https://www.norwall.com/product_pdfs/2141_rs20a_om_2_2017.pdf
