Has to do with the available bandwidth on the wifi network wrt protocol.
For example:
Unless the 2.4GHz wifi is set for n-only, you will have only a 20MHz wide network with only one channel.
n-only on the 2.4 GHz network spreads it across 2 wifi channels for a 40MHz network.
Compare that to the 5GHz network that potentially spreads it across 4 wifi channels for 80MHz in ac mode.
