sarah leach
9 years agoNew Poster
If no IP address then you need to restart unit to gain IP address for unit
Restart unit to get IP address for modum
See, I truly am getting you mixed up with someone else. You DID say that you had other devices, the other person didn't. SMH. It's been a long day.
Anyway, I didn't think it would help, but, if the laptop has the ability to connect with a LAN cable, you can make the security settings adjustments mentioned in the other thread with that. Or, you can try doing it with the laptop while connected through WiFi, but it would be best to do it while LAN connected if you have that ability.
Davey
8 years agoFreshman
Thanks alot I will try that tommorrow. Get some sleep.
