sarah leach
10 years agoNew Poster
If no IP address then you need to restart unit to gain IP address for unit
Restart unit to get IP address for modum
10 years agoModerator
Rebooting or powercycling a device is always worth a try. :) Thanks for sharing, Sarah!
Davey
9 years agoFreshman
Are u saying to restart the router or my tablet? My other devices are connecting.
- Davey9 years agoFreshman
Ok but my tablet is not showing an IP address only a Mac # ,whatever that is, in the wifi settings. Thanks
I don't know exactly what the OP is referring to, as in actual IP address or IP Gateway Association State, but
if your other devices are able to connect,it's most likely a settings issue that is not allowing your Android based tablet to connect.It won't hurt anything to power cycle the HT2000W modem (unplug it at the outlet, wait 30 seconds, then plug it back in), but I don't know that it will help. You can always try.
Edit: Sorry, I'm getting your issue mixed up with another. You didn't sate you had any other devices.
