tvignoe
10 years agoNot applicable
- 10 years ago
BirdDog
10 years agoAssistant Professor
Netflix works but there is the data limit. No HD, but SD or low definition can be done without eating through excessive amounts of data. Again, still a limit depending on plan amount, can't expect satellite internet to replace cable TV or satellite TV. Low definition Netflix uses about 300 MB per hour, SD about 700 MB per hour.
- 11 years ago
