tvignoe
10 years agoNot applicable
- 10 years ago
_rs
Any feedback from other customers regarding the feasibility of using AT&T's MicroCell (yet another cellular extender over internet device)? Here's a link for more info: http://www.att.com/att/microcell/
Would be nice to not have to secure another account for a land-line service.
- 11 years ago
