farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
Gwalk900
9 years agoHonorary Alumnus
farmerhugh,
One thing you may wish to check for each computer is the power settings for the network adaptor.
This is from Win7 but others are similar:
- 11 years ago
