Wifi going down
For the last two weeks my internet goes down 1 or 2 times a day. The Hughes Net modem lights (the ones that are lite) are solid. When I reset the modem it comes back up. Is there any way you can check on your end and see if theres a problem with the modem?? Thanks for your help.
- BirdDogAssistant Professor
Hi farmerhugh, have you checked to make sure it isn't something on the WiFi side timing out like the router or the adapter on the device? The first things to check when connection is dropping out. Thanks.
- Gwalk900Honorary Alumnus
Hi Farmerhugh,
Try to imagine following a path ... a communication path ... and there is one
The "path" is going to consist of a point starting with a computer or device and the first thing encountered along the path (either wired or wireless) is your Router. Its "address" along the path is 192.168.0.1
The next place along the path is your Modem, its address is 192.168.0.1
Rather like this:
In the above we can see and travel the entire distance of the path and we can "visit" places along the path by entering it IP address. In the above that path starts at the computer and extends all the way to the Internet.
Now what happens if the path is washed out or blocked at certain key points?
If the path is broken at Point 1 (somewhere between the computer and the Router) we can not reach the first waypoint along the path nor any point beyond it. This problem is within the users Network.
Lets look at another place the path can be washed out or broken:
In this case we can enter the address of the first waypoint and be able to "see" it ... that is our Router. If we can see the Router we know our path is intact that far.
With the path broken as in the above picture if we try to see the second waypoint along our path (the Modem) we can not "see the Modems SCC at 192.168.0.1
We then know the break is between our Router and the Modem. It could be a WAN (Wide Area Network) issue with our Router, cable between the router and the modem, a IP address conflict or even a dead Modem. At least we know the general area of the break. This would dictate that we connect a computer directly to the Modem, thereby shortening the path and once again see if we can contact the Modems SCC at 192.168.0.1
There is one more place that a break can occur:
Here as we follow the path .. Router (192.168.1.1), good we can "see" it. Modem (192.168.1.1) good to point ... we can see the SCC and we may see some error codes listed but some connections are not going to work ... as an example we may get null values for remaining data.
This is a problem starting at the Modem and going outward towards the Hughes Gateway.
This can be due to a modem failure, ODU failure or a Gateway problem. The type of error codes listed in SCC will give some insight.
- farmerhughJunior
This should read "internet " going down. Not too sure I like this new format. We were having problems with the wifi a couple months ago after Amanda sent us a new router that problem went away, I don't see an edit button.
The EDIT button is the three little dots highlighted here in the righthand upper corner of the reply:
So by "internet going down" it still could be anywhere in the three break points I posted above. You will not have Internet access if there is a break in any of them.
When this happens can you access the Modems SCC?
What are the codes if any listed?
Do you know how to access the Modems State Code Monitor?
Again, when you have an issue the questions ... in order are:
Are all five of the front panel Modem LED's lit?
Can I see the first address along my cable path, the Router? (192.168.1.1)
Can I see the second address along my cable path, the Modem SCC (192.168.0.1)
Finally, is my Modem "seeing" the Gateway and Internet? (access remaining data info, access to a website)
- farmerhughJunior
I have to wonder if this isn't the same problem Chicagojohn is having. I also am in Illinois. i can't figure out how to check the numbers you gave me to use, I go to my browser type in the numbers and get a bunch of web pages. I also can't figure out how to put a "snip" picture on these replies as I used to. I apologize as I am really computer challenged. I know I m doing this wrong.
Assuming you are connecting wirelessly, you would first open a browser, put your mouse in the browsers address bar and click the mouse then enter the numbers 192.168.1.1
Don't forget to enter the decimal points where shown.
This will bring up your Routers log in page.
If you can't reach the Router in this manner it is indicative of a wireless problem between your computer and your Router or a Router configuration problem.
Next you would do the same but instead enter 192.168.0.1
If the Modems SCC page opens this means you have connectivity through the Router and into the Modem.
While there you should be able to see any listed error codes and you should also be able to see your remaining data allowance. The latter means your Modem is connected to the Hughes Gateway and you should then also have access to the internet.
As to snips, open the snipping tool and take the desired screenshot and then save it to your desktop.
Once save you can add it to your community post by clicking the camera icon just above your post with the word Photos next to it, navigate to where you saved the snip and then hit the upload button and then hit the reply button to post your reply.
- farmerhughJunior
- 11 years ago
