farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
9 years agoDistinguished Professor IV
farmerhugh,
If you look to the left on the picture you posted, you'll see a setting that says "Change Adapter Settings" (pic 1). Click on that. Right click on the adapter (mine says Ethernet) (pic 2) and click Properties. Then click "Configure" (pic 3). After clicking Configure, click on "Power Management" (pic4). Then you should see the picture that Gwalk posted. Make sure the highlighted item is NOT checked. If it is, uncheck it and click Okay.
- 11 years ago
