farmerhugh
9 years agoJunior
Wifi going down
Could someone tell me what the indicators are for a router going bad. My wifi keep shutting down suddenly and I don't think its the internet. It seems to spring back to life when I wake up my wired...
- 9 years agoHey farmerhugh
Thanks
9 years agoDistinguished Professor IV
Glad you like it. It's a decent router with a fairly good range. My folks also have the same one and my stepfather can go anywhere in his two story house with his laptop.
I've also found absolutely zero drop in speed between being directly connected and using this router.
- 11 years ago
