Wireless printing with Hughesnet HT2000W
For the WPS method, you may need to enable WPS in the modem. To check, go to the System Control Center, click on WiFi Settings, use admin as the password, click Advanced Setup, Wireless, then WPS. Make sure the WPS box is checked. If not, check it, click Apply Changes, X out of the page and try pressing the WPS button and connecting again.
If it still doesn't work, and it won't work connecting it by way of the SSID and password, the following thread may help...
Okay thanks I followed the instructions in the other thread and was able to make it work thanks
