lake_woman's avatar
8 years ago
Solved
Cannot connect to wireless HP D110 printer with Gen5 wireless
The printer sees the 2.4 network but will not connect. I've entered the password correctly and also tried WPS. What do I do now?
  • Your printer may not support the wireless security cipher the HT2000w uses by default...
    1: Visit http://systemcontrolcenter.com or http://192.168.0.1
    2: Click Wifi-Setting on the left
    3: Enter the password to access your wifi settings, by default it is   admin
    4: On the 2.4Ghz tab change the WPA Mode to WPA/WPA2, your cipher suite should change to TKIP+AES
    5: Try reconnecting the printer, using the password that is displayed in the password field on that section.
  • C0RR0SIVE's avatar
    C0RR0SIVE
    • LKS's avatar
      LKS
      Thanks for this - I had this problem as well and this took care of it. :)
    • Sassy's avatar
      Sassy
      Thanks so much for this post!!  We struggled for 2 days with this issue.  We used this and Viola!!!  We are printing!!!
