I like my gen5 plan but we were lied to about data usage
Hi Robp1, welcome and thank you for reaching out to us on the community! I appreciate you bringing this to my attention, I hope I can clarify things up for you. We unfortunately can't guarantee speeds will be exactly between 1-3mbps; they will have variances. To quote from our website here that goes over all the legal details:
"All Service Plans feature the No Hard Data Limits where the user can continue to use the Service without being charged for additional data usage. If a user uses more data than is provided in the monthly plan, he or she will experience reduced data speeds, until their next billing period. Reduced speeds may be as low as or lower than 1 Mbps and may cause Web sites to load more slowly or affect the performance of certain activities such as video streaming or large downloads/uploads."
With your HughesVoice, please correct me if I misunderstood, but it sounds like you're using it when you call in for tech support; what may be happening when you call in to tech support is, if they have you reboot your modem, your phone line gets cut off as well. So it's best to let them know if you're using your Hughes phone prior to them doing any troubleshooting.
I hope this clarifies things.
-Brooke
- Robp1JuniorThe original complaint was the sales rep lied to complete the sale. We have really good luck with gen5 however, our raisin continues to malfunction causing low speeds (even with the 20 gigs) after the data is used we had some problems accessing stuff however, it still worked well enough to make Calls. Now that the data is used and the radio is messing up our phone service disconnects mid call, and some days our best speeds are as low as 128k. When our gen5 equipment is working correctly after resetting everything we can do almost anything. But now resetting the modem does not seem to help, and calling tech support is a joke, because it disconnects mid call and no one can call in or out. We have no cell service here or land line making it even harder to get this mess sorted. I have the insurance on the stuff but can’t seem to utilize it.
I want to clarify some things to make sure I understand:
- Are you experiencing slow speeds before you reach the end of your monthly data cap?
- Are the calls disconnecting once you've reached your monthly data cap?
I ran a diagnostic and I don't currently see any issues, but that doesn't mean there isn't one. I'd like for you to try some steps for me.
1. Unplug the ATA (Voice unit).
2. Unplug the HughesNet modem at the wall outlet or power pack (Do NOT unplug from the back of the modem).
3. Wait for at least 30 seconds after unplugging the HughesNet modem, then plug the modem back in.
4. Wait for about five minutes so that the HughesNet modem is fully back up and running, then plug in the ATA.
5. Make sure all the cables are securely attached.
Let me know if that helps!
-Brooke
- 12 months ago
