Solved! Go to Solution.
Thank you for reaching out and I am sorry to hear you are experiencing this. I also apologize for the delay in response. I took a look into this and ran diagnostics on your equipment myself. I can definitely confirm that your signal strength is extremely low but the modem itself does seem to be functioning properly. This means a re-point is required and a possible radio replacement as well. The radio replacement depends on the results after the dish has been re-pointed. If you do end up having a technician come out, they will have a radio transmitter replacement ready to be installed, just in case. While I do wish this could be resolved remotely, a re-point of the dish and possible replacement of the radio would need to be performed by a technician on site.
At this time, your options are to have a technician sent out either by calling our support number or having me process one specifically, or upgrading to GEN 5. Both of these would resolve this issue but based on your previous comments, I'm sure a repair is what you are leaning more towards. Please let me know what you would like to do going forward.
-Damian
