Only 2 lights on - power and lan - does not reset all cables tight
Spectator
This morning the modem for our hughes net went out. I reset the wifi and tested. Issue is in the hughes net modem. The LAN and Power lights come on when unplugged and replugged, but the it doesn't go through the normal process. It just sits for hours with the LAN and power on only. Can I reset and how? Can I get a new modem?
1 ACCEPTED SOLUTION
Accepted Solutions
Re: Only 2 lights on - power and lan - does not reset all cables tight
Hi tsao,
I'm glad you found the community, thank you for reaching out, we can certainly take care of this for you. I'm sending you our latest modem model, the HT2000w. You won't need to return your HT1100, just be sure to dispose it according to your local electronics waste regulations. Here's a guide to setting up your new modem when it arrives in a few days: http://support.hughesnet.com/faq/internet/where-can-i-find-replacement-guide-ht2000w-satellite-modem
If you have any other concerns, feel free to contact us again!
2 REPLIES 2
Hi tsao,
Spectator
Thanks
