jaybat71's avatar
jaybat71
6 years ago
Changing password on wifi.
How do I change WiFi password if I forgot old one?
    jaybat71
    While using a device that is directly connected to the HughesNet modem via LAN cable, go to this page and sign in using admin as the password.  Once there, you'll be able to see the password on the right side of the page for each radio (2.4Ghz, 2.4Ghz Guest, 5Ghz and 5Ghz Guest).  You can change the password(s) there, if you wish, as well.
    Hope this helps.  :)
  • Good morning jaybat71,
    I'm glad you found the community, thank you for posting. I hope Gabe's suggestion helped out. If you have any concerns feel free to drop by the community again, we're here for you.
