Hughesnet Community
Coax to ethernet
Lions_02
Coax to ethernet
Is there any way to convert the coax cable coming from the dish to an ethernet cable so that I can get rid of the hughesnet router?
1 ACCEPTED SOLUTION
infinitytec
Junior
No. In order for it to work you will need a modem. However, it has to be a HughesNet-compatible modem. As far as I know only HughesNet makes those. The HughesNet modem has WiFi built in, but you could use another router, if that is what you want.
Ryzen 7 2700/16GB RAM/X470 Motherboard/250 GB m.2 SSD/2TB HDD/4GB RX560/Windows 10 Pro
1 REPLY 1
infinitytec
Junior
