Data Usage/Ad blocker
mcdruid
Just wanted to share my 2 cents worth on this subject.  Have been with Hughes for 5 years and suffered agonizing usage numbers.  Long story short, finally downloaded free version of Ad blocker( 30 day trial) and saw immediate results.  I actually had data remaining !!!!!!OMG seems all those pesky ads and other unwanted notices were eating up data.   Anyway,  annual subscription under $40 worth the hassel of not running out of data near the end of the billing period.
1 ACCEPTED SOLUTION
Accepted Solutions
Re: Data Usage/Ad blocker
You should move your post to https://community.hughesnet.com/t5/Third-Party-Products/bd-p/ThirdParty
Free ad blockers work just as well
Reader View is also a useful app to have.
6 REPLIES 6
  There's plenty of free shareware add ons out there, I'm running AdGuard and NoScript.  I recently had a spike in my data usage that I traced to a Firefox upgrade disabling NoScript.  I removed NoScript and then reinstalled it, and things went back to normal.  I believe that a Java script blocker like NoScript may actually save more data than an ad blocker.  Kind of a pain to deal with though, since a lot of sites won't work properly without Java Script.  Some will warn you that they need Java Script some not.
AdBlock Plus and uBlock Origin, to name a couple.  Both very popular and work well.  Gotta make sure to uncheck "Acceptable Ads" in the options of the former.
monicakm
Senior
DEFINITELY!
I use the free AdBlock Plus.
Thanks for sharing mcdruid! Glad that solution is working out for you. I'm going to move this to our 3rd Party Products board.
Slow performance? Click me!
MarkJFine
Professor
If you people only knew how much embedded ad images, css, and javascript there is in a conventional web page you'd faint.
Not only from file size and data usage perspective, a lot of these have to be downloaded from various sites other than the one you're on - making the site much slower to load due to having to resolve each address and any associated latency.
Sites with a lot of images also take a lot of data. The images themselves are usually very resolute and scaled down to size for display. It adds up, so it pays to not automatically display images on social media, etc.
