HughesNet Community
DirecTV
kmksg
DirecTV
Hi,
I unplugged the DirecTV set-top box and turned my TV off, but under Wifi setting on my HughesNet, it is still showing that my DirecTV is connected.  I'm trying to save data.  Can someone help?
5 REPLIES 5
MarkJFine
Professor
The DirecTV box will be connected to the internet whether it's turned on or off. 'Off' for the DirecTV box is just a standby mode. The only way to completely disconnect it from the internet is to unplug the lan cable from the back of it, or reset the internet connections in it's settings.
Likewise, turning the TV off just puts it in standby as well. So if you have it its internal wifi set to use HughesNet it will use it at will until you've removed the TV's wifi settings from the TV.
All this said, some devices may still show as being connected in the Connected Devices for a while after disconnecting. Sometimes the list just needs to be refreshed.
Thank you.  I'll try it tonight.
inthewoodsworki
I am having trouble disconnect Directv from the wifi...any suggestions?  how do I tell if it is still connected?  Is there a way to force a connection to stop from hughesnet?
Have you tried going to the settings?  EDIT: you may also want to as the DirecTV community: https://forums.directv.com/categories/directv/60d0c0f0e3304518e522a420
To see what's connected, go here: https://my.hughesnet.com/en/usage/connecteddevices
You have to reset the network settings in the DirecTV receiver, though I can't remember exactly how it's done.
Welcome to the HughesNet Community!
this resource.
