BirdDog
11 years agoAssistant Professor
Curse my smart TV !!!!!!
It just sucked 790MB for whatever reason, probably a firmware update, thought I had all that automatic stuff turned off. I was doing so good with my allowance for the month, no longer. :( Am glad I...
CharlesMcCool
11 years agoNew Poster
Same here plus it does not support IPv6, also the version your running. did you get it from the Beta folder? if you did go back to the download page again because there is a final release not in the Beta folder
