ebb plus upgrade
shadowwalker.20 , are you and your mother part of the same household? Do you reside at the same address? Th EBB is limited to one monthly service discount per eligible household. A household is defined as any individual or group of individuals who are living together at the same address and share income and expenses. So if you two are part of the same household, the problem may be something else. The reps on this site may be able to find out what's going on.
EDIT: For more info, see https://www.hughesnet.com/emergency-broadband-benefit-program, which also links out to the government agency that manages the program.
- Remy4 years agoModerator
shadowwalker.20,
Thank you for reaching out! Since your mother is the account holder, she would need to be the one applying for the EBB benefit. The information provided to us by the USAC has to precisely match what's on file in our system. In the meantime, I'll go ahead and downgrade you back to the 20GB plan. Once your mother has applied for EBB and is sent a confirmation email, I'd strongly recommend reaching back out to us so we can help get it applied to the HughesNet account.
Remy
- shadowwalker.204 years agoJuniorThe account holder now shows that i herbert cook is the one who's name is on the bills name. So there should not be a problem. with me getting the ebb applied. My mother gave all my info to the rep and I had to agree to the terms and conditions yesterday. If i have to call back to talk to a rep I will. Thanks In advance
- shadowwalker.204 years agoJuniorafter getting account holder changed everthing should be fine now. i was approved for ebb. This should be a done matter thanks for all your help. Herbert
