(Edit, Liz thank you!!) Mislead upon sign up, charged a different price, and slow speeds
Good morning Swmk,
Ah, I see. Thank you for that. I've PMed you with a resolution.
Hi,
Please check your private messages (PM) in the top right corner of the community page I will send you a PM shortly to further address your billing concerns.
What are you trying to do online? I just ran diagnostics on your site to ensure the HughesNet equipment is working normally and everything is checking out OK; we're delivering plan appropriate speeds to the modem.
So we can begin addressing your speed concerns, please create a testmy.net account and run 3-5 tests during different parts of the day. Post your test results link here in your thread.
Only testmy.net speed test results are accepted to be considered for escalation to our corporate engineers. Tests from other sites like speedtest.net are not accepted due to the compression technologies and latency that satellite deploys.
-do the tests while directly connected to the HughesNet modem with a LAN cable (wifi must be disabled*, NO third party Router or Wireless devices can be used for testing)
-use the 25MB size download test file
-post your results URL here, it may look something like http://testmy.net/quickstats/yourusername
For a more in depth guide on running the tests, please visit: http://hninfo.us/speedtest
*If you don't know how to disable the wifi in the HT2000W, read "How do I manage my built-in WiFi modem?" in this PDF: http://customer.kb.hughesnet.com/Documents/1041318-0001_a.pdf Click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, 2.4Ghz Guest, 5Ghz, 5Ghz Guest).
- Swmk7 years agoFreshmanHi Liz.
Sent you a PM. As far as the service speed goes I told him I was working from home on my laptop and needed to watch live streaming video from a CCTV system. He assured me the service he sold me would work just fine for that, however it does not. It just freezes. It was actually faster when I did a hot spot from my phone. However I kept the service simply because we watched Netflix every once in awhile, but it lagged on that too. So now I’m moving and can’t have it where I’m moving and even if I could, I’m on the ground floor surrounded by trees.- Liz7 years agoModerator
Good morning Swmk,
- Swmk7 years agoFreshmanI just want to say that Liz has gone above and beyond to resolve this issue. I appreciate you Liz, and I appreciate your understanding, compassion and time helping me get this figured out. You are my hero.
Thank you!!
