Not what I expected
First, the $1 is used as an account check. When that account check occurs your financial institution holds that $1 from your available balance. Within a week or so that hold drops off, as again, it's only for an account check. It's not a charge.
Regarding your streaming issues, assuming that you're looking for help, the first step would be ensuring that you are not out of plan data. You can do so here. If you are NOT out of plan data, the second step is running some speed tests. Regardless of what you may have been told on the phone, the help available here requires a specific site to be used and for the tests to be run in a specific way. The protocol for those speed tests is as follows.
-if testing upload instead of download, use the manual 4MB size upload test file
- 6 months ago
