Plan reset, lost tokens.
Hi fox12,
Thank you again for your patience and cooperation. I've sent you tokens to make up for all this. Please don't hesitate to stop by the community again if you have any other concerns.
I have also had a reset on all my terminals, not sure of my tokens as I never look at them, or buy them, or anything of the sort, but it appears this data reset and token issue might be a bit wider spread...
I bet if you look at your terminal status, it will show that you got reset as well.
Hmm. My data seems correct on my Usage Meter, the iPhone app, as well as the web site.
That said, I've been noticing a tremendous (nearly painful) amount of SSL errors since late last week so I'm wondering if that's affecting authentication errors in many instances and it's causing data retrieval errors and possibly data corruption as a result.
