Harvey Evacuees Need More Data
Hi Pramoin,
I'm glad you found the community, thank you for posting. You are amazing for helping out; we certainly can lend you a hand as well. Please check your private messages in the top right corner of the community page as I've sent you a PM to further address your concerns.
Hi Pramoin,
- Liz9 years agoModerator
No envelope icon?
In any case, try this link, should take you to your PM inbox: https://community.hughesnet.com/t5/notes/privatenotespage-Liz
- Pramoin9 years agoNew PosterLiz, I still have no tokens anywhere.. i was using my iPhone to see my pm inbox but now I have logged in using my laptop, and still no tokens?.. i dont know where they are suppose to show up at.
Open the modems SCC at 192.168.0.1
There you will see your remaining Anytime Bytes, Bonus Bytes and Token Bytes Available.
Pramoin wrote:
Liz, I still have no tokens anywhere.. i was using my iPhone to see my pm inbox but now I have logged in using my laptop, and still no tokens?.. i dont know where they are suppose to show up at.Remember, also, that Token Bytes are only utilized when the data in the given time period is exhausted. The Token Bytes also roll over, so if you don't utilize all, or any, of the Token Bytes, what you have remaining will stay with you to utilize at a later time.
8AM - 2AM Service Plan data, then Token Bytes.
2AM - 8AM Bonus Zone data, then Service Plan data, then Token Bytes.
Good morning Pramoin,
I sent you data tokens which need to be activated. To activate, you do so via the Support Center > Usage > Buy Tokens > Click Use:
Alternately you can do this via the Usage Meter, click on the Buy Tokens button to get the same window as above. Let me know if you have additional questions.
