Sales Call Review
Thank you for providing me this information. I was able to locate the account. After running diagnostics, it appears the equipment is fully operational, however, we are unable to run a remote speed test due to frequent time outs. This could be due to the fact that both your site location and Gateway location are experiencing heavy cloud coverage at the moment. This can interfere with the signal and our remote tools as well. In the meantime, I would like to get your speeds documented before I begin reviewing the sales call. Also, once I launch the investigation, I will be listening for guarantees of speed or any other misinformation that may have been stated.
In regards to running the speed test on testmy.net, here are the instructions below:
Please do these tests while directly connected to the HughesNet modem with a LAN cable (wifi must be disabled*, NO third party Router or Wireless devices can be used for testing) -use the 25MB size download test file ONLY.
-post your results URL here, it may look something like http://testmy.net/quickstats/yourusername
For a more in-depth guide on running the tests, please visit: http://hninfo.us/speedtest *If you don't know how to disable the wifi in the HT2000W, read "How do I manage my built-in WiFi modem?" in this PDF: http://customer.kb.hughesnet.com/Documents/1041318-0001_a.pdf
Click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, 2.4Ghz Guest, 5Ghz, 5Ghz Guest).
-Damian
sunny day, no clouds, I suggest you have one of the technicians use BirDog, I cant run test now.
But the issues your having show you that there is a site problem..
Have a tech use BirDog.
