Reduced Monthly Charge Ordered by Moderator Not Taking Affect?
cybercycle1,
That's correct! A discount for the next 5 months was applied, and I had already previously added the 20 dollar credit for this past month.
Remy
Remy wrote:cybercycle1,
Thank you for posting! It seems you're right, the discount wasn't added as it should've. I'll go ahead and apply a credit for this month's charge, and I'll make sure the discount is added as it should be this time. Once it is completed and applied, I'll update you here!
Thanks
Remy
Thanks Remy....I appreciate your follow-up.
John
cybercycle1,
I checked just a moment ago to make sure, but it seems like the discount has been applied! We appreciate your patience!
Remy
- cybercycle15 years agoJunior
Remy
Thanks for the confirmation, Remy. Based on the original arrangement, I will assume the discount will be applied for the next 5 months?
John
- Remy5 years agoModerator
cybercycle1,
Remy
