TKay's avatar
TKay
7 years ago
Solved
Help please, Amanda or Liz, moderators
This is my first time to post.  We have been with hughesnet for 2 years in Oklahoma with slow but managable service. Now we've moved to Arkansas and (supposedly) upgraded to Gen5 and had nothing but problems getting the upgrade.  After 4 lengthly phone conversations, we are still on the slow Gen4 service (actually slower than before) but being charged for Gen5.  Each rep says the problem is solved and will show up from 24 to 48 hours and I am still waiting. I have never received the promised callbacks or emails other than the survey.  I see I am one of many that has this same problem. That certainly doesnt speak well for the company.   If either of you could respond to this, it would be deeply appreciated to think that someone is listening - better yet, fixing the problem.
T. Kay
  • Hi TK,
    This has been fixed, your Gen 5 plan is in effect. Please let me know if you have any other concerns.
  • You're very welcome TKay, I'm glad you found the community so we could sort this out for you! Feel free to drop by again if you have any other concerns.
  • Hi T.Kay,
      I see it's your first post here, so welcome to the community! We can certainly take care of this for you. I pulled up your account to investigate and for some reason the Gen 5 order is blocked in the system. I just need to let the billing folks know to fix that. I'll escalate this to them, but keep in mind as it is after regular business hours, they may not get to this until next week. I'll keep an eye on this for you and make sure you're fully on Gen 5.
    • TKay's avatar
      TKay
      thank you.  I will be awaiting your solution.  I appreciate your quick response.
    • TKay's avatar
      TKay
       Hi Liz. Just checking in to see how things were moving along with the gen 5 upgrade.  Still shows gen 4.    Would appreciate hearing from you.
      Thank you,
      TK
      • Liz's avatar
        Good morning TK,
        Thanks for checking in, I pinged our billing folks to make sure my request on your behalf didn't slip through any cracks; they're usually very expeditious. I'll reach out to them again and let you know.
