Retailer told me I would get the 50GB for $99.99 for 24 months
Clearly the retailer didn't set it up correctly. Best to bring it up with them.
Here's an update to my problem. Apparently my initial installation was not done correctly and my equipment was not properly reporting my bandwidth usage so I was misled into thinking I would only need 20GB and changed my plan.
Not long after they sent a tech out on a service call and fixed the "problem", which I wasn't aware I had until it was fixed.
Then it began reporting correctly and I monitored my usage for awhile, prorated it out and decided I would need closer to 50GB so I changed back.
Because of a faulty install/equipt, whatever, I am now off the $99 special and on the regular $129.99 price.
I don't feel I should have to pay more due to something that was out of my control.
