What happens to my email if I switch or cancel my current plan?
It's still the case! :)
Though I'm not 100% on this, I'm pretty sure you lose access to the email service.
If you're even just thinking of switching, it wouldn't be a bad idea to get an email account through Gmail or Outlook or similar and start using that. They're free, and IMHO, better than HughesNet's email, anyway.
- hcamardelle6 years agoSophomore
Got that set up, but there's stuff I don't want to lose should I switch. It may be worth my while to take my plan to the lowest price type and move on from there. Thanks GabeU!
You're very welcome. :)
If you mean that you have emails saved that you don't want to lose, there's an option to forward them to your other email. You should be able to see the option at the top when you select an email. If that's not what you mean, hopefully you'll eventually be able to find some kind of workaround for what you're referring to so that you wouldn't have to keep paying for service just for the email. There's no doubt that doing so would get annoying very quickly. :p
Thanks GabeU. I got my welcome email from HughesNet mid May, 2007. It'd be a lot of forwarding. LOL. I likely need to sort through things and keep the important stuff.
