What happens to my email if I switch or cancel my current plan?
It's still the case! :)
You're very welcome. :)
If you mean that you have emails saved that you don't want to lose, there's an option to forward them to your other email. You should be able to see the option at the top when you select an email. If that's not what you mean, hopefully you'll eventually be able to find some kind of workaround for what you're referring to so that you wouldn't have to keep paying for service just for the email. There's no doubt that doing so would get annoying very quickly. :p
Thanks GabeU. I got my welcome email from HughesNet mid May, 2007. It'd be a lot of forwarding. LOL. I likely need to sort through things and keep the important stuff.
Ah, okay. I see what you mean. Juuuuuuust a tad bit of forwarding. LOL. :p
Edit: I just found the following in another thread. It's from a HughesNet rep. It's from 2017, so hopefully a rep will confirm whether this is still the case....
"Your HughesNet e-mail will automatically close 45 days after your account is closed. If you want to keep your contacts, you can use the export feature in the HughesNet webmail page to save a copy to import to a new e-mail account."
- Liz6 years agoModerator
