Why do I have less data on the first of the month than what I pay for each month?
Good morning Kelley,
You're out of Anytime Bytes, so as a courtesy I've sent you some complimentary tokens to help you download GlassWire and investigate your unknown data usage.
To use your data tokens, access your Usage Meter (the application or online). Click the Buy Tokens button. The next screen will show you the number of tokens available for use. Click the Use link next to the number of tokens you have. This will increase your TOKEN BYTES AVAILABLE amount, not your Anytime Bytes, and restore speeds.
Thank you, Liz. Now that it's Monday, I'll attempt the download again and will advise.
- Liz7 years agoModerator
Hopefully you're already getting acquainted with the GlassWire software. As it is a third party product, us mods can't provide support for it, but you're free to ask other customers here like yourself for any tips on using GlassWire.
For your convenience, here are links to their user guide and their support forum:
https://www.glasswire.com/userguide/
Hi, I'm gonna close this thread since it's gone inactive. Please start a new thread if you have any other concerns.
