10 years ago
WHY I GET NO REPLIES and HOW DO I CHANGE COMMUNITY SETTINGS?
Well, as Gwalk and I are working together on the long-standing DDDD issue, he suggested that I check the SETTINGS on the Community. Well, NO WONDER I GET NO REPLIES . I tried changing them myself ...
10 years agoModerator
Good morning Larry,
No worries, good idea making the thread private, we wouldn't want the whole internet seeing your e-mail login information.
Our community uses single-sign on that lets HughesNet customers sign in one time to access all their online resources, such as e-mail, the support center, and the community. When you register and create a new HughesNet account, that is used for everything, including the community.
If you would like to change your e-mail address for the community, please follow these steps:
While logged into the community, click on your username in the top-right corner.
The click on the Profile link in the drop down menu:
On your community profile page, click the Email & Notifications link in the top left area:
Here is where you can update your e-mail and notification settings.
I believe you have to have an e-mail address on file at all times, so be sure to ADD your desired e-mail address first before you REMOVE the one you don't need.
Also make sure you have the appropriate options checked if you wish to receive e-mails when others reply to threads you've participated in.
Hope that helps.
Hope that helps.
