C0RR0SIVE's avatar
C0RR0SIVE
8 years ago
HT1100/2000w Web Acceleration MACRO
Gonna actually start working on fixing macros and making new ones...  Like previous Macro Threads, I will post the Macro in use between +++++ lines so you know how it appears, and throw the full macro "code" into a code box.  Make sure you copy the entire macro and paste it into your macro box and title that macro appropriately if you wish to use the macro.  Make absolutely sure you copy from <p> to </p> in the code box at the bottom of this post.  There is no need to "test" the macro unless you wish to make sure you copied it properly.
If the images aren't loading properly, please let me know before you bother using the code.
GabeU BirdDog Gwalk900 maratsade MarkJFine
Please follow the directions below to disable Web-Acceleration.
1: Visit http://192.168.0.1 in your web-browser.
2: Click the "i" icon at the top of the HT1100/2000w System Control Center (also known as the SCC).  It is highlighted in red in the image below.
3: Click on "Web Acceleration" then "Control" outlined in red.
4: Click on "Web Acceleration Enabled", this will change to an orange button that says "Web Acceleration Disabled".
photo mQGk0j9
5: Restart your browser and try using the service that isn't working, please let us know how that works for you.
<p>Please follow the directions below to disable Web-Acceleration.<br><br>1: Visit <a href="http://192.168.0.1" target="_blank">http://192.168.0.1</a> in your web-browser.<br>2: Click the "i" icon at the top of the HT1100/2000w System Control Center (also known as the SCC). &nbsp;It is highlighted in red in the image below.<br><img src="http://i.imgur.com/skUivVb.png" border="0" alt="photo skUivVb.png"><br><br>3: Click on "Web Acceleration" then "Control" outlined in red.<br><img src="http://i.imgur.com/JnchLQt.png" border="0" alt="photo jnchLQt.png"><br><br>4: Click on "Web Acceleration Enabled", this will change to an orange button that says "Web Acceleration Disabled".<br><img src="http://imgur.com/mQGk0j9.png" border="0" alt="photo mQGk0j9"><br><br>5: Restart your browser and try using the service that isn't working, please let us know how that works for you.<br><br><br></p>
