Air fryer?
I don't have one, but someone I know does, makes wings all the time in the air fryer, and loves it. Talks about how awesome it is. All.The. Time. :)
EDIT: he did mention one downside, and that's that it only cooks small batches, which is a little inconvenient when he has company.
maratsade wrote:I don't have one, but someone I know does, makes wings all the time in the air fryer, and loves it. Talks about how awesome it is. All.The. Time. :)
That's encouraging! :)
And he's right, it is pretty small, but it's just me, so it should be able to do enough. According to the little booklet that came with it, the capacity for wings is 2lbs, which is pretty good. :)
It sounds to me it's perfect for just one person. Do report back after you've used it!
GabeU wrote:
And he's right, it is pretty small, but it's just me, so it should be able to do enough. According to the little booklet that came with it, the capacity for wings is 2lbs, which is pretty good. :)- GabeU6 years agoDistinguished Professor IV
maratsade wrote:It sounds to me it's perfect for just one person. Do report back after you've used it!
For sure.
- Liz6 years agoModerator
I think my parents have that air fryer. Use it a lot for chicken wings and ribs. Pretty good! Crispy and juicy wings... :heart: Hope you enjoy your air fryer!
