Horrible Upload Speed, Week 3
"Did you bother toggling the Video Data Saver? "
GabeU, this is neither here nor there, but I personally see no difference when I have toggled the VDS. Then again, my connection is rather wonky and eccentric.
maratsade wrote:"Did you bother toggling the Video Data Saver? "
Yeah, if it's already wonky, it's probably not going to make much of a difference. LOL.
GabeU wrote:Yeah, if it's already wonky, it's probably not going to make much of a difference. LOL.
Well, that would explain it, then! LOL
(From the question in the other thread) - My speeds are still quite good, but not as steady as they used to be. I'm more affected now during peak usage periods, though not usually too badly.
I'm back to the way it used to be when they first installed Gen 5. Noticeable latency and odd speed dips (and not just during the evenings). And I don't get the high speeds others get (hovering between 17 and 20 Mbps, down to under 10Mbps, sometimes less, at peak times). Gen 4 was more stable for me -- I imagine Gen 5 will get there.
- 12 months ago
