Ricky
8 years agoTutor
Laptop problem
My laptop is having issues. It got Microsoft updates yesterday evening. I told it to install them and shutdown. I get up this morning and it will not show the desktop. It will turn on. It did this mo...
Well, that's good. If, in fact, you are unable to fix the issue, at least you'll only be out a little time and data, and you won't lose anything important.
I save a system image once a month and keep them going back three months. I don't really have anything on my computer that I can't afford to lose, either, but restoring an image is so much easier than doing everything all over again. This desktop didn't come with Windows 10, though I'd be able to install W10 from a user created disk due to it being registered with a Windows 10 digital certificate. Still, though, I would then have to go through the updates, program installs and settings adjustments again, and that's at least a few hours worth of work. Ten minutes vs a few hours. Um...I'll take the former. LOL.
I hope you are able to get it fixed without too much hassle.
Ricky, if you haven't reset your laptop yet... Did you check Comodo's updates regarding the issue? https://forums.comodo.com/news-announcements-feedback-cis/comodo-internet-security-v10016254-released-t120010.0.html
If that doesn't fix it... are you unable to rollback the update? I had pretty much this exact issue after the Anniversary update but it had to do with my beta Nvidia driver. If you can rollback, uninstall Comodo, then update again and see if that works.
~Amanda
I am resetting the laptop as we speak. I do not know if it was Comodo that messed it up. I know I got a Microsoft update. Not sure about any Comodo updates. Thanks for the suggestions. Starting over.
Laptop seems ready for the rebuild. Will make it a weekend project. Gonna put a hurting on my download allowance.
