HughesNet and Irma.
I say good on ya!
Very smart thinking creating an alignment pin. The mount, pole and dish are not items you ever have to return anyway. Getting the dish and radio inside out of harms way was the way to go. Chances are if left on the pole everything would have been damaged or destroyed including a bent/unset/off vertical pole.
Good old American ingenuity is what made this country great back in the day. I give you kudos personally.
Come to think of it an alignment pin should be something on all installs.
I say good on ya!
BirdDog wrote:I say good on ya!
The pole is schedule 40 pipe it can take a beating, the dish not so much and the TRIA pole is fragile.
While removing and resetting the antenna not in regulatory compliance, I would much rather have my antenna up and operating after the storm versus looking like this.
I have done a ton of satcomm work and have a Birdog meter I don't know if ti could be used to properly align a HughesNet antenna.
