Some thoughts after 3 months usage
Very informative.
And, though this isn't the Tech Support section, I may be able to help with the Javascript error with the Usage Meter. It's actually an issue known to hit some systems. Why, and why it only affects some, I have no idea. I'll paste the instructions to fix it below, which were written in another thread by MarkJFine.
And, to see the AppData folder referenced in the instructions, you may need to change your folder view settings to show "hidden items." In Windoows 10, when in C, click "View" (at the top) and then check the "Hidden items" box over to the right. After you're finished, it would be a good idea to uncheck that to rehide the things that shouldn't normally be shown. Other versions of Windows should be similar in showing the hidden folders.
1. Fully quit the Usage Meter from it's own menu by clicking on the donut in the menubar and clicking "Quit".
2. Look for the following directory
Windows: C:\Users\[your User name]\AppData\Roaming\
Mac: /Users/[your User name]/Library/Application Support/
3. Carefully delete just the "HughesNet Usage Meter" directory under that and empty the trash.
4. Restart the Usage Meter. This will regenerate all the underlying information as if it were run for the first time, thus correcting the error.
